Journal ListingWindow question
Ehaviv
Computer
IL
Hi
These journals identical one write to a file only and the second to a file and window
the output of 'write to a file only' have 2 blank lines more then of the 'write to a file and window'
can somone know and explain what hpen
Thanks in advanced.
Journal 1
Code:
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
 Module ListingWindow_SelectDevice_DeviceType_FileAndWindow
  Sub Main()
    Dim s As Session = Session.GetSession()
    Dim ufs As UFSession = UFSession.GetUFSession
    Dim workPart As Part = s.Parts.Work
    Dim lw As ListingWindow = s.ListingWindow
    Dim nowDateTime As String = Nothing
    Dim window2file As String
    nowDateTime = Format(Now, "_ddMy_hhmmss")
    window2file = "C:\_nx11_\journal_directory\FileAndWindow_" & nowDateTime & ".txt"
    'use listing window to write to file and window
    lw.SelectDevice(ListingWindow.DeviceType.FileAndWindow, window2file)
    ufs.Ui.ExitListingWindow()
    lw.Open()
    lw.WriteLine("=========================================================")
    lw.WriteLine("")
    lw.WriteLine("ListingWindow.DeviceType.FileAndWindow = " & window2file)
    lw.WriteLine("")
    lw.Close()
    'flush file buffer by changing listing window device
    lw.SelectDevice(ListingWindow.DeviceType.Window, "")
  End Sub
 End Module
output 1
Code:
ListingWindow.DeviceType.FileAndWindow = C:\_nx11_\journal_directory\FileAndWindow__05618_073317.txt
Journal 2
Code:
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
  Sub Main()
    window2file = "C:\_nx11_\journal_directory\File_" & nowDateTime & ".txt"
    lw.SelectDevice(ListingWindow.DeviceType.File, window2file)
    lw.Open()
    lw.WriteLine("")
    lw.WriteLine("ListingWindow.DeviceType.File = " & window2file)
    lw.WriteLine("")
    lw.Close()
  End Sub
 End Module
output 2
Code:
ListingWindow.DeviceType.File = C:\_nx11_\journal_directory\File__05618_073702.txt
Cowski thank you.
I'm also running nx 11027.
I'm upset.
I test it in my company
and I get the same added newlines.
whom add these redundant newlines. ?
Hi
I added some code to work around but I'm still
wonder why this ocurring.
Code:
Option Strict Off
Imports System
Imports System.IO
Imports System.Text.RegularExpressions
Imports NXOpen
Imports NXOpen.UF
  Sub Main()
    Dim window2file2 As String
    nowDateTime = Format(Now, "_ddMMyy_hhmmss")
    window2file2 = "C:\_nx11_\journal_directory\File_" & nowDateTime & "_2.txt"
    lw.Open()
    lw.WriteLine("")
    lw.WriteLine("")
    lw.WriteLine("")
    lw.WriteLine("")
    lw.WriteLine("")
    lw.WriteLine("")
    lw.Close()
[b]
     Dim sr As System.IO.StreamReader = New System.IO.StreamReader(window2file)
     Dim r_str = sr.ReadToEnd()
     sr.Close()
     r_str = Regex.Replace(r_str, "[\r\n]+", vbCrLf & vbCrLf)
     Dim sw As System.IO.StreamWriter = New System.IO.StreamWriter(window2file2)
     sw.Write(r_str)
     sw.Close()
[/b]
  End Sub
 End Module
I should clarify my previous post. By "identical output", I meant that both of your posted journals give me the exact same result and neither had the extra lines that you are seeing. I do NOT get the extra lines that you are seeing no matter which version of your journal I use. I would suggest contacting GTAC, perhaps it is something in your configuration or a bug in the NXOpen API.
www.nxjournaling.com
Hello Ehaviv,
It isn't clear (to me) if maintenance pack MP7 (or mp8 or mp9 or mp10) is installed in addition to the 11.0.2.7. maintenance release. There were listing window changes delivered in MP7. (Just making sure that this seven 11.0.2.[highlight #FCE94F]7[/highlight] is not being misinterpreted as meaning MP7).
HTH, Joe
