I need to ask of what use is such data? For one square inch of a face you are suggesting 100000 x, y anz z values. Before considering producing a journal for such data can I suggest you indicate how you would use such point data. NX faces can be checked for face type and then far less data is required. For example if you had a planar face then edge information and three points is all that is required. If the face belong to a dumb solid then it is still possible to use far less points to get sufficient face data. To determine if a face is planar use a number additional points and test both distance and curvature would give the info so that again the edge info and three points is all that is required. Similar reduced data is required for cylindrical, conic and spherical faces. For general B surface I would suggest fundamental B surface creation data or constant u and v data.
Frank Swinkels
