Stenbrook
- Dec 5, 2014
- 125
So I am just curious as to what people typically specify and what the reasoning is behind the methods used, but I have worked for two companies and the first one would always provide Wide Flange beams at the column lines for steel roof and floors and then infill with joists between them. My new company however does not think there is any need to provide a beam at the column and that it is cheaper just to use a joist. So my questions are as follows:
1. Do you typically provide joists or wide flanges at your column lines?
2. Is it really cheaper to go with joists or is this inaccurate?
3. Are there any other reasons to go with one way over the other?
Thanks in advance for your input!
