In an older house a floor heater was cut into the flooring and wood joists. One joist cut. No reinforcing was done. There is vibration transmission from one side to the other around the floor heater. The opening was blocked to adjacent joists. It is not feasible to take up the entire floor to redo the joists completely so they must be reinforced from the bottom. There is no access to the top of the joists. Joists are unfinished redwood 7.5" X 2" at 16" and span 13'.
Can I double up on the adjacent joists - what type of nailing and overall length would be required?
Jack S
Jack S
