B
bretonh
Guest
Hello All,
I need to join several splines into a single spline so I can use it in a slot (point on line) assembly mechanism.
The splines are all straight lines connected between two points, but they are not in the same plane.
Ideally, I'd like to create a single entity made up of straight line segments through the points, but I can't find how to do this.
I'm using WF5.
See attachement
Can anyone help?
I'm using WF5.
See attachement
Can anyone help?
