It depends on your requirements for the assembly. Is it for "show-n-go" or is it to share design information?
Rather than creating new joined parts, you can save (depending on SW version) your assemblies as SLDPRTs. This turns everything into surface models.
Or you can save your entire assembly as a parasolid file. This will output each part as a solid model, but the file size will be much smaller.
If the assembly needs to be a full parametric models, some discussion on this happened last month.
thread559-107220
thread559-107611
[green]"But what... is it good for?"[/green]
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read faq731-376 to make the best use of Eng-Tips Forums?
