JohnRBaker Pts_Along_Any_Curve_to_txt-file.grx 2
Duniry
Aerospace
Dec 1, 2016
11
thread561-379920
Hi John,
I used your grip file to output the points on a spline.
It works great, thanks!! Would it be possible to increase the number of points??
Once i go above 1000,I get an error. Any help would be much appreciated!
If you have the GRIP Author license, you can make the change yourself.
Just find the array definition line that has (1000) on it and up the value.
Ben Loosli
Change this line to suit, then compile and link to make a new grx:
ENTITY/PT_CURVE,CUR_PTS(1000)
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Can anyone tell me if it is possible to get the points in reverse order also.
Maybe you could point me in the right direction...
...Maybe it can be done more easily using a different method? Knowledge fusion?
Thanks in advance [bigsmile]
If you familiar with the grip programming
read the points array from array length to 0
I mean from last index to 0 instead of
From 0 to last index.
I don't remember if in grip the array index
Start with zero.
any way from last index to first index.
Or reverse write cur_pts to a new array
and use the new array.
Thanks a984928!
I'll see if I can make sense of your suggestions and get back to you.
May be you can change this line
to go down from NUMPTS to 1
may be something like this
DO/S40:,N,NUMPTS,1,-1
$ Write Data Points to Scratch Area
DO/S40:,N,1,NUMPTS
PTXYZ=&POINT(CUR_PTS(N))
WRITE/1,USING,DATA_FORMAT,N,PTXYZ
S40:
I think you may be on to something there.
I'll give it a go.
My last post should works
because it reads the points in reversed.
from array index NUMPTS to array index 1
Excellent work a984928!
Works perfectly. Thanks.
Hopefully I can figure out how to make it write the points in one direction and then the other.
Thanks again!
Any idea why I can't see the input prompts? ('Enter Name of Data File','Select Curve','Have You Selected the Correct Curve?')
Hopefully you can
Because now you have the two DO loop
The original one from 1 to numpts
And the new one from numpts to 1
Now you need a user choice input
and an IF statement to run the original DO loop
Or the new DO loop
To do this I need refresh my grip knowledge
With no promise I'll try to.
Thanks to your help, it's working fine.
The input window has no description.
It's just for user friendliness.
Try it
Replace this code
Code:
$$  Write Data Points to Scratch Area
	DO/S40:,N,1,NUMPTS
S40:
With this code
Code:
BCK010:
CHOOSE/’Select Points Reading Order’,$
’Default Order’, $
’Reverse Order’, resp
IFTHEN/ resp == 1
JUMP/ BCK010:
ELSEIF/ resp == 2
JUMP/ TERM1:
ELSEIF/ resp == 5 $$ Default Order
$$  Write Data Points to Scratch Area in Default Order
	DO/S40:,N,1,NUMPTS
S40:
ELSEIF/ resp == 6 $$ Reverse Order
	DO/S60:,N,NUMPTS,1,-1
S60:
ENDIF
Thanks again a984928. That failed compilation I'm afraid.
My only problem is that the title bar of the user input gives no description - ('Enter Name of Data File','Select Curve','Have You Selected the Correct Curve?'). It still works fine, but it would be nice to see the correct prompts.
I currently have it writing the points in both directions.
My next goal is to have it output 2 files , PT_FILE+'-forward' and PT_FILE+'-reverse'.
This file tested and working it writes 2 files
1 for forward points data
2 for reverse points data
Code:
$$	Program Name:  Pts_Along_Any_Curve_to_txt-file
$$	Program to extract points from any type of curve
$$	and write the X,Y,Z coordinates to a txt file.
$$	Part file must be open and set as the Displayed part.
$$	Data file, saved in the 'C:\Temp',folder
$$	is formatted as a 'comma delimted' text file which will
$$	make it easier to convert to an Excel Spreadsheet.
$$	John R. Baker, P.E.
$$	Siemens PLM Software Inc.
$$	Digital Factory
$$	10824 Hope Street
$$	Cypress, CA  90630
$$	714-952-6032
$$	"john.r.baker@siemens.com"
$$	Written:  August 21, 2011
$$	Updated:  February 14, 2015  Changed default data folder location to C:\Temp
$$  Declare Parameters
	STRING/PT_F1(60),PT_F2(60),HEADER(3,50),DATA_FORMAT(132)
	STRING/PRT_NAM(30),CURVE_TYPE(9,10)
	NUMBER/NUMPTS,PTXYZ(3),PRTNAM_LEN,PRTDIR_LEN,CUR_CLR,CUR_WDTH
$$  Define Data File Headers
	HEADER(1)='Part File Name:  '
	HEADER(2)='X,Y,Z Coordinates of Points on '
	HEADER(3)='PT #       X          Y          Z'
	DATA_FORMAT='#@@@,#@@@@@.@@@,#@@@@@.@@@,#@@@@@.@@@'
$$  Set Defaults
	NUMPTS=50
	CURVE_TYPE(1)='N/A'
	CURVE_TYPE(2)='N/A'
	CURVE_TYPE(3)='Line'
	CURVE_TYPE(4)='N/A'
	CURVE_TYPE(5)='Circle'
	CURVE_TYPE(6)='Conic'
	CURVE_TYPE(7)='N/A'
	CURVE_TYPE(8)='N/A'
	CURVE_TYPE(9)='Spline'
	CUR_PTS(1)=POINT/0,0,0
	&FULLDT=1
$$  Extract Part Name
	PRT_NAM=&PNAME
	PRTNAM_LEN=LENF(PRT_NAM)
	PRT_NAM=SUBSTR(PRT_NAM,1,PRTNAM_LEN-4)
	DRAW/OFF
	MASK/3,5,6,9
$$  Initialize Scratch Area
	CREATE/TXT,1
	CREATE/TXT,2
$$  Write Header Data to Scratch Area
	WRITE/1,'Points Data in forward Direction'
	WRITE/1,' '
	WRITE/1,HEADER(1)+PRT_NAM+'.prt'
	WRITE/1,' '
	WRITE/1,TIME+' - '+DATE
	WRITE/1,' '
	WRITE/2,'Points Data in reverse Direction'
	WRITE/2,' '
	WRITE/2,HEADER(1)+PRT_NAM+'.prt'
	WRITE/2,' '
	WRITE/2,TIME+' - '+DATE
	WRITE/2,' '
$$	Define name of Data File
S00:
	TEXT/'Enter Name for forward DataFile',PT_F1,RESP
	JUMP/S00:,TERM1:,,,RESP
S01:
	TEXT/'Enter Name for reverse DataFile',PT_F2,RESP
	JUMP/S01:,TERM1:,,,RESP
S10:
	DELETE/CUR_PTS
$$  Select Curve
S15:
	DRAW/ON
	IDENT/'Select Curve',PT_CURVE,RESP
	JUMP/S00:,TERM1:,,RESP
	CUR_CLR=&COLOR(PT_CURVE)
	CUR_WDTH=&DENS(PT_CURVE)
	&COLOR(PT_CURVE)=186
	&DENS(PT_CURVE)=2
	CHOOSE/'Have You Selected the Correct Curve?','Yes','No',RESP
	JUMP/S15:,TERM1:,,,S20:,,RESP
	&COLOR(PT_CURVE)=CUR_CLR
	&DENS(PT_CURVE)=CUR_WDTH
	JUMP/S15:
$$  Set Number of Points
S20:
	DRAW/OFF
	PARAM/'Enter Number of...','Points',INT,NUMPTS,RESP
	JUMP/S10:,S00:,,,RESP
S30:
	WRITE/1,HEADER(2)+CURVE_TYPE(&TYPE(PT_CURVE))
	WRITE/1,' '
	WRITE/1,HEADER(3)
	WRITE/1,' '
	WRITE/2,HEADER(2)+CURVE_TYPE(&TYPE(PT_CURVE))
	WRITE/2,' '
	WRITE/2,HEADER(3)
	WRITE/2,' '
$$  Define Points on Curves
	CPSET/EARCL,PT_CURVE,NUMPTS,CUR_PTS
	DO/S40:,N,1,NUMPTS
S40:
	WRITE/2,USING,DATA_FORMAT,N,PTXYZ
S60:
$$  Write Additional Header to Scratch Area
	WRITE/1,' '
	WRITE/1,'********************************************'
	WRITE/1,' '
	WRITE/2,' '
	WRITE/2,'********************************************'
	WRITE/2,' '
$$  Select additional curves
S50:
	CHOOSE/'Select Another Curve:','Yes','Finish Program',RESP
	JUMP/S50:,TERM1:,,,S10:,,RESP
	WRITE/1,' '
	WRITE/1,'End of File'
$$  Save Scratch File Contents to the Point Data File
	FILE/TXT,1,'C:\Temp\'+PT_F1+'.dat',IFERR,ERR1:
	FTERM/TXT,1
	FILE/TXT,2,'C:\Temp\'+PT_F2+'.dat',IFERR,ERR1:
	FTERM/TXT,2
	DELETE/CUR_PTS
	MESSG/'Data File Created and Saved:','C:\Temp\'+PT_F1+'.dat'
	MESSG/'Data File Created and Saved:','C:\Temp\'+PT_F2+'.dat'
	JUMP/TERM1:
ERR1:
	MESSG/'Data file Saving Error!','Program Terminating!'
$$  Exiting Program
TERM1:
	MASK/ALL
	DRAW/ON
	HALT
$$	Disclaimer:
$$	This code is provided for illustrative purposes only.
$$	The example has not been thoroughly tested under all
$$	conditions. We therefore, cannot guarantee or imply
$$	reliability, serviceability, or function of the program.
$$	The code contained herein is provided to you "AS IS"
$$	without any warranties of any kind. The implied warranties
$$	of fitness for a particular purpose is expressly disclaimed.
 http://files.engineering.com/getfile.aspx?folder=6c62452c-cd68-46c6-b231-b1e6db641e4a&file=Pts_Along_Any_Curve_to_txt-file_08.grs
