Gray and ductile cast iron pipes have been e.g. push inserted inside various types of casings e.g. installed by various boring, jacking, and tunneling means as well as larger existing pipelines for many decades. This has been described to some extent for many years with regard to "Highway and Railroad Crossings" in a section of ANSI/AWWA C600 as well as AWWA Manual M41. I agree with Mr. BigInch that boring, jacking, or tunneling with conventional casing pipe, and then placement of a carrier pipe (often from the common boring/jacking etc. pit) for watermain or sewer service, is probably still the most common approach.
There are however now available many styles of quite formidable strength ductile iron pipes that can also be installed by many different “trenchless” (or perhaps more accurately in many cases, “less trench”) means, e.g. as can be observed through the portal
where same procedures are preferred and acceptable to authorities.
We have seen increasing numbers of these projects since the early 1990’s, with a marked increase in horizontal drilling projects with flexible, restrained joint ductile iron pipe since 1996. I would only further point out that with contemporary ductile iron joints/systems, the long piping assembly/layout area mentioned in some of this thread (as a disadvantage common to HDD with other types of pipes) is not necessary with ductile iron pipes, as the very rapid assembly of these contemporary joint structures does not require lengthy field welding and/or cooling periods, and thus also allows for quick insertion of individual pipes, e.g. in a relatively short “pipe insertion/assembly pit”, in “cartridge” loading fashion. In fact, in the first 6” (`150 mm) ductile iron project I saw installed by HDD in 1996, I think the pipe never even hit the ground after a pulling head was assembled onto the first plain end and dropped down to connect to the drill string behind the reamer, but thereafter the pipes were basically loaded from a stack on a flat bed truck that was parked next to the pipe insertion pit, which in turn was basically just a “trench box” for worker joint assembly safety that had been quickly dug/sunk into a rectangular trench with a backhoe that the contractor had drilled to/reamed from at desired pipe depth.
