Iyc - Cold Formed Steel - 2001 AISI
dkrpink
I am looking for input on the Iyc value used in Eq. C3.1.2.1-14 in the 2001 AISI Standard for a C channel member with lips.. I have been taught it is simply the Iy published by the manufacture divided by 2. I am not sure if that is correct. Additionally I have seen other engineer’s calculations that use the full value of Iy as the value of Iyc. I think the key is in the proper interpretation of the definition of Iyc but I think it due to the terminology it can be misinterpreted. Anyone have an opinion on if Iyc is Iy/2 or the full value of Ic or another value?
By "a C channel member with lips", I assume you are referring to a continuous stiffened edge?
_____
[ ! Here, and
[_____! Here?
Mike McCann
MMC Engineering
For those of you who don't do much cold formed design, Iyc is the weak axis moment of inertia of the portion of the C-shape which is in compression.
I use 1/2 of Iy.
DaveAtkins
Mike; Yes a C-channel like you drew.
Thanks for your input Dave.
Does anyone else agree with Dave with Iy/2 or feel it is another value?
