Hello. I've used the forum several times in the past for information, but just recently decided to join.
I have a Gould's 3196 1x1.5-8 that is under vacuum on the suction side of the pump (-15 to -20 in hg). The pump is supposed to pull the water out of the tank and feed some nozzles that spray down on a filter belt. The issue is that we are getting very little flow the through the nozzles and the tank is filling up. As a result, the excess water is being pulled in to a vacuum pump and overloading it. The gauge on the discharge is reading 4 psi and does begin to raise when discharge valve is closed. When the suction line is opened and closed, nothing changes on the discharge gauge, it reads 4 PSI. There is no notable build-up or wear in the pump bowl or impeller. Impeller clearance is correct. With vacuum off the tank and the tank full of water, no leaks were noted on the pump seal or suction line. One small leak was noted on a recirculation line that goes from the pump discharge back to the tank. Any other ideas as to what to look at?
Thanks in advance.
KDUN
Thanks in advance.
KDUN
