Isolation valve for sewage
rgvrider
AU
I'm after an isolation valve for a waste water treatment plant. Our inlet pipe is above the level of the treatment plant, so on power failure of the plant, I would like to isolate the inlet flow so:
1. The pipe does not drain and draw air through vacuum valves.
2. The inlet tank does not overflow as the inlet pipe drains to it.
My thought is to use a straight through diaphragm valve, with a pneumatic fail closed actuator and a energised closed solenoid on the outlet of the actuator. This way, if we have a power failure, the solenoid with de-energise, release actuator air pressure and close the valve.
This is on a DN250 pipe line, sub 5 bar operating pressure. Has anyone got a better solution or other ideas? I think this solution may be expensive I'm not sure diaphragm valve is best for sewage (ideally knife gate).
Single acting (spring return) pneumatically operated knife gate valve using solenoid valve as you have suggested.
Knife gate valve will cut through any debris whereas a diaphragm valve may only partically close .
For a DN250 mm the post from stanier above is also in my opinion correct, and this will normally be the cheapest choice, and also technically satisfying.
Maintenance: piston rod and knife to be checked and kept lightly greased with waterproof grease.
Others to be considered:
Gate-valve (more suspectible for debris)
Double eccentric plug valve (cost much more)
As a failure safe solution electrical with UPS (battery backup) is possible but will need a longer closing time, and for this size cost considerably more than pneumatic with spring or pneumatic with air vessel power-source backup.
