Would just like information please on whether or not it is a ASME/ISO standard requirement to have some kind of isolation for a flange (for ability to take it offline for maintenance) or just an industry practice.
I currently am in discussion with the site engineer that the firewater tank's outlet line (4"-flange-2"-pump) should have some kind of isolation mechanism for the flange in between the 2 lines(i.e. a valve to be able to stop the flow from the water tank before the flange), since with its current assembly, the whole water tank needs to be stripped if any leakage happens or recertification is required for the flange. His argument is that it is a low pressure activity and leakages rarely happen (17m high water tank)
Would like your thoughts on the above and thanks in advance.
