I recently worked on a large residential renovation. The plans showed a wood framed fireplace with a sheet metal flue liner. No call out were made to the type of fireplace insert.
Apparently they installed this - It weighs about 2000 lbs when all is said and done. They are having issues with the firebricks cracking.
By the numbers, there is enough wood structure beneath it, however, it is installed where there is a flush girder that is slightly higher than the adjoining joists. My suspicion is this and the deflections in the floor system are causing the problems. I am working on a fix with the contractor.
He has not asked me for any money yet to help offset his costs. My feelings are this...
1) I had never even heard of these things prior to a couple of weeks ago. Every fireplace insert I have designed for (as far as I know) was a lightweight metal thingy.
Is it incumbent on me to be familiar with all fireplace insert technology?
2) It was not called out on the plans so how was I to know I needed to design for a 2k load. If I had known, I would have simply added a large masonry pier under it.
3) Should the contractor have asked me, "hey, we are putting 2k of masonry on this floor, is it designed for it"?
4) What responsibility does the Arch. have in this?
Apparently, Isokern has two models - one designed for a slab and one for a wood foundation. Seems like a wood foundation is a bad idea for anything this brittle and heavy. It is also sited in an area with plastic clay soils so differential pier movement may also be an issue.
Thanks in advance for your input.
