loiner
- Mar 19, 2010
- 1
Engineersedge( & has two equation sets for required thread engagement length. One is "ISO" and the other is FED-STD-H28/2B. I am looking at a M56 (metric) bolt with nut tensile strength 430MPa and bolt tensile strength 850MPa and the two sets of equations when modified by the J factor give big differences. The FED-STD-H28 gives a much lower/better value. Which equation set should I use for a M56 bolt ? Where do the "ISO" equations come from (they are not in ISO898)?
