Hi Guys, 2 Quick Questions:
Working to ISO. I have a rectangular part that I am showing in 5 orthogonal views on a 2D drawing. There are a total of 6 holes in the part. 2 are visible in the front view, 2 in the rear view, and 1 on each side view (L & R). The 2 rear holes are 9mm in diameter, and the rest are 6.6mm in diameter. If I were to specify one hole with a 2x 9mm callout in the rear view, is it clear that this is only relating to that specific view? In general, is it assumed that any multiple-hole callouts specified in a specific view are only relevant to that view? Or is there some other way to designate that the 2 x 9mm holes are ONLY the holes shown in the rear view and not in the other views? Is there a clean way to designate, also, that the rest of the holes in the other views are all 6.6mm diameter without dimensioning them separately in each view?
Second, in some cases I have found myself wanting to show only the top and bottom views, or only the front and back views of a part on a 2D drawing. This is likely a very basic question, but can I skip views on the drawing and make it clear that the views are the top and bottom, and not the top and front, for example? How would I designate this on the drawing correctly working to ISO? Would I just write the view name underneath the view or something? The drawings are all in first angle projection.
Thanks!
Thanks!
