LittleInch
Petroleum
Before anyone replies "Of course it is", let me explain further.
The use of a Corrosion Allowance in pipelines carrying mildy corrosive fluids - typically I'm talking CO2 corrosion here - has been around since the dawn of pipeline codes when the result of any issue was to throw metal at it. This works and in reality is not a huge cost when looking ar relatively short pipelines, say <100km. However, for big inch long distance lines each mm represents millions of dollars. The corrosion rate is nowadays calculated using various algorithms backed by experimental data with various factors and arrives at a (far too exact) figure for uninhibited and inhibited corrosion rates over the life of the pipeline, often in the 2-4 mm range for say a 95% CI availability.
My issue has always been that corrosion like this doesn't occur as a whole scale removal of that amount of material, but in relatively small locations with pitting type corrosion. With the advent both of intelligent pigs to both detect and define any areas of metal loss, any corrosion found does not necesarily reduce the operating pressure of the pipeline when you use the calcualtions now available in B31.G and RSTRENG etc. These were not available when pipeline design codes were being written.
Thus where you make an insistence in the operating manual that CI is injected continuosly and regular inspection occurs, do you need to include a CA for the whole pipeline and instead concentrate it in specific areas or zones where it is either more probable (high temp, high pressure, low spots or locations where it is difficult to return to fix it later (road crossings, HDD etc, where a 0.6 DF might exist anyway. Why spend tens of millions of dollars now to protect small areas of pipeline in the future?
Clearly there is a risk balance to be made, but with the tools and calculations now available to deal with pitting corrosion as to whether it is a problem or not or provide additional external sleeving or other remedial measures, is the use of CA still valid in its full calculated state or can it be reduced to 50%, 25% or 0% of the inhibited rate. Your views most welcome.
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
