I had charatered the oil by using hysys. The result shows at 40C which is the temperature I was told the crude will be trucked in, the viscosity of the oil is about 2100cp. Does anyone has the experience on handling such high viscosity oil? Is this oil capable to flowing at this temperature? What would be the criteria to sizing the offloading line? With less than 1 psi/100ft pressure drop, the fluid velocity is about 0.6 ft/S. Is this resonable?
I will be really appricated any thoughts on this!
