Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
ManoloGalarraga said:Mterials for PED must be included in an harmonized standard for pressure vessels steels.
Can you elaborate where in para 4 this is directly or indirectly implied? Im not saying I dont agree on using structural steel for main pressure bearing parts on pressure equipment, however (purely from a legal perspective) if the PED is not explicit in this matter, there's a basis for argument with a NoBo during a conflict.KVdA said:So in fact using S355 or S235 is a big no no, and in conflict with the annex 1 §4 PED requirement
Vikko said:For the PED law, you have to use harmonized standard
XL83NL said:even not all EN standards are harmonized.
EN 10025-2 is not a harmonized standard.vikko said:For the PED law, you have to use harmonized standard: EN 10025-2 is one of them, so you do not need PMA (that is needed only for ASTM materials)).
Table 4-2.1 applies only for low temperature steels. EN 10025-2 does not contain low temperature steels.vikko said:When this is not specified into the material standard, you can evaluate it with very low (they are really low which finally makes unpractical to use such material above ambient temperature or for ) coefficient up to 300°C only, according to table 4.2-1 of EN 13445-2.
