Is there a 2d drawing viewer?
  • Thread starter Thread starter jarf70
  • Start date Start date
J
jarf70
Guest
I'm looking for a 2d drawing viewer.
Anyone know of one.
Jeff
The free viewer from PTC that works in your internet browser can view pro E drawings. It aslo works with 3D models. It is called product view express. You need to change some config options in proE and resave files for these to work, that is all covered on the FAQ. http://www.ptc.com/products/pvexpress/index.htm
That's fine as long as he doesn't have intra-link. Otherwise you will need the full version of product view.
If you just ned to share the drawing use Ghostscript(FREE) and make pdf files, you can set up a mapkey to do it automatically, then if you need to you can set up a web page to view all of your drawings.
If you already have Adobe Acrobat you can just use Distiller to create pdfs from postscript files. No need for Ghostscript.
