Is it possible to reorder views in the Catia V5 spec tree?
Tetragrammaton
Aerospace
Nov 27, 2002
85
Hi all,
From a general 'house keeping' point of view I would like to know if it is possible to reorder the views in the spec tree?
Pls also ref attahed screenshot.
In current spec tree I have under Annotation Set.1 the following:
Front View.1
Front View.2
Section Cut View.1
Section Cut View.2
Section Cut View.3
Section Cut View.4
Section Cut View.5
Section Cut View.6
Section Cut View.7
Section Cut View.8
Section Cut View.9
Section Cut View.10
What I would like to do is move the two 'Front' views down after all the Section views - is this possible or do I have to plan what views I will have first?
Alternatively can I create another Annotation Set, for example Annotation Set.2?
Seeing as there is Annotation Set.1 is seems to imply that there could be additional sets; in which case how do I create another Annotation Set?
Thanks in advance.
Best regards
Dave
Best Regards
Tetragrammaton :)
Right click in the spec tree on the front view and under the front view.object you have reorder
In R20 you can right click - View Name object --> Reorder the view. I do not have prior versions of Catia installed to verify this in 19 or 18.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Hi Gents,
Many thanks for the good responses
However I must apologise as in my haste I have omitted that I have R18.
So unfortunately there is no reorder :(
Thanks anyway for your time.
Best regards.
Dave
Best Regards
Tetragrammaton :)
Strange, I don't have R18 installed but I checked the documentation for R18 and the reorder is listed there as a new function... could it be SP issue? I remeber that on R17 I used cut and paste to reorder sheets, could that work for you?
