I had the occasion recently to work with a 480V circuit. For a temporary hookup in a University environment, a prior visitor had installed a 240V 20A 3ph +ground female connector body [L15-20] on the 480V cord, which is switched at a fuse/ switch box nearby- perhaps 20 ft of cable. The unit tested draws only perhaps 5 amps. I changed the connector body to the proper L16-20 unit for 480V service, but then had to make an adapter in order to connect the cable into the facility's equipment for a very temporary and closely supervised test.
I was later instructed by my supervisor that the L16-20 connector body must be replaced with the incorrect but formerly installed 240V L15-20 connector body, so that the plug would be left interchangeable with the facility's equipment.
Under duress, this change was made, and the connector body and cable were annotated "480VAC". The facility operator was informed that I found this improper setup disturbing, because sooner or later someone is going to come along and plug a 240V machine into that L15 plug and apply 480V to it, resulting in damage and/or perhaps injury or death. I feel that this situation puts my company and myself at risk for liability for any such damage arising from this situation.
Because of personal interactions with my supervisors, who were present, I cannot bring up this issue with them. In fact, the whole company is not very receptive to constructive criticism.
What say you electrical experts?
No worries, it's a controlled environment?
Send a report to OSHA?
Report it to higher-ups in the company?
There are other safety issues in this environment too, but this seems the most egregious violation.
