I have an application for an oil flow meter in a Class I, Div II, Grp D envirnoment. We have always used a REN Slow Flow meter for this lube oil measuring task. However, this meter has no electrical approvals at all. I am told by the manufacturer that it can be used in hazardous locations with the use of a zener barrier.
How can I prove to an inspector that this is an aceeptable practice? Is this an acceptable practice? The flow meter is a purely resistive switching device. It cycles between 1 kOhm and 1000 MOhm as it switches. Used with a 24VDC input, this device generates a pulse train that we use to measure the oil usage. If this is acceptable, what code can I point to?
![[banghead] [banghead] [banghead]](/data/assets/smilies/banghead.gif)
Thanks,
Chris Foley
Midland, TX
Thanks,
Chris Foley
Midland, TX
