I'm trying to create a calculation package for a pressure vessel that does not have a standard shape (i.e. not a shell, hemisphere, conical, etc.) Is there a way to perform this calculation under Division 1 rules? For instance, if I can fit a hemisphere entirely inside my part, can I design it as a hemihead knowing that my calculation is conservative? I would appreciate your reasoning either for or against using this approach.
My second question is regarding the 3000 PSI limit in U1(d). Is there any clarification about what the "additional design principles and construction practices" are for vessels rated above 3000 PSI?
Thanks,
Thanks,
