radiocontrolhead
- Mar 4, 2017
- 95
Long time lurker, first time poster.
I am trying to understand the idea behind a floor mesh and how to generate a reasonable one in etabs manually. I am trying to achieve proper connectivity between the slab and walls and find it to be difficult when the slabs are to be modeled with intentions of capturing in plane forces/deformations (semi-rigid). The modeling procedure at my current workplace is to assume the slab as a "null" shell element and to add an additional mass to this shell where only the lateral resisting elements will be considered. I have since realized it is a very barebones approach to yield preliminary results and may not account for all conditions as described below for this project. I find that I have to apply a line load above walls to account for vertical loads, and to divide these shells so that connectivity is achieved between wall and slab, and then further refine the mesh in the horizontal direction. it's essentially a backdoor approach. Wanted to hear what others thought of this? Slabs are designed using a different slab design software, say, Ram Concept.
Project Info:
approximately 10" thick conventional slab with a large opening in the centeral region for a pool and spa. These will be supported on grade but the perimeter walls are essentially retaining walls, designed separately. The northern slab edge is supported by a 13' retaining wall that supports a surcharge of a 3 story wood framed structure above it. The idea is that this slab acts as a pool deck for the wood structure at the slab level.
Few questions:
1) are there any guidelines to producing a mesh to achieve connectivity between the walls and slab? The automesh feature in Etabs just doesn't produce results that I am looking for mainly due to the irregularity.
2) Based on the mesh I have generated (attached), will I need to model each individual plate for the slab or is there an easier way to have etabs break the slab into these segments based on an uploaded DXF file?
3) Is this far more work than is absolutely required and am I overthinking this design?
4) Depending on the connection between the top of the northern retaining wall and slab (say pinned and not allowed to slip), is it reasonable to assume that the core walls surrounding the pool will be the primary resisting elements in providing an "at-rest" retaining wall condition?
4) I understand I can account for the opening by treating it as a deep beam using a simple beam analogy, but if i wanted etabs to calcualtie these in plane stresses i would need to model as "semi-rigid" with a manually generated mesh presented above?
5) Just for giggles, how would you treat a design as such? I am only trying to pick the brains of other engineers and their approach to this problem.
I really appreciate everyones time with this. Although this may or may not be(depending on responses) an overkill approach, I will use it as an exercise to understand the underlying concepts for future projects.
Project Info:
Few questions:
