Iron and manganese in ground water 6
jocky
Agricultural
Jan 14, 2001
1
Has anybody had any dealings with a company in San Francisco called 'World Construction Company'? I'm wanting information on their ground water filter media high contact oxidation membrane. Can anybody recommend it?
Thanks, Ross Douglas, New Zealand.
What method of treatment are you using (greensand filtration, aeration/sedimentation/filtration)? This will have an affect on what chemicals you might want to use.
To answer your question, Chlorine has a Stoichemic dose of 0.63 for Fe and 1.29 for Mn. KMnO4 has a dose of 0.94 for Fe and 1.92 for Mn. These doses are the parts of Cl2/KMnO4 needed for 1 part of Fe/Mn.
If you use Cl2 for oxidation of Fe, you will need a total of (47*0.63) or 29.61 mg/l of Cl2. If KMnO4 is used to oxidize the Mn you will need (4*1.92) or 7.68 mg/l of KMnO4.
My experience has been that Mn is hard to treat; however, when the Fe/Mn ratio is 10:1 or better, the Mn co-precipitates out with the Fe on a relatively easy basis. I have not had iron levels as high as yours however.
Both will oxidize the metals; however, because of the higher cost for KMnO4, chlorine is more economical to use. It's drawback is the slow precipitation of the Mn. The KMnO4 has a higher oxidation rate (just a few minutes). Both may require pH adjustment dependent upon your water characteristics.
Cl2 will precipitate the Mn; but, at your high levels KMnO4 may be needed to make the plant smaller and less costly. I would plan for it as the costs involved are low (metering pump, storage tank, and mixer).
