mprice
- Nov 25, 2001
- 22
Is it possible to buy paint which absorbs IR light?
I would like to measure the temperature of a small target (1mmx1mm) using an optical pyrometer. The problem is that I will probably end up measurinmg the reflected heat from the the surfaces around the target. It has been suggested that I could paint around the target with a paint that would reduce the IR reflections. Any clues?
Matt
Matt
