Z
Zestje
Guest
I'm trying to make a parametric involute gear. I have taken a good hard look at all the examples I could find, but have some questions I can't find the answers to.
Let's start with these:
When I create the involute curve which defines the shape of the tooth, at which diameter does it start? I've seen the base and root diameter being used as well as sometimes even the pitch diameter.
E.g. in examples which use the base diameter the tooth geometry between the base and root diameter is drawn as a straight line which doesn't seem logical to me.
And does the start of the involute shift when changing nothing on the gear except the clearance?
If I find some time I'll post some pics or an example part...
