Hi! I have gotten access to a file "involute_curve.prt" and was wondering if you could help figure out how to change it. I am unsure what 't' represents. I am fairly certain 'r' is my generating radius. Can you help? Please and thank you! - Kim
The involute curve is a parametric equation (a "law curve" in NX terminology). The "t" is the parameter that ranges from the value of 0 to 1 that helps drive the curve definition. The "t" must appear in the equation for the curve, but as JohnRBaker points out, it is under the control of NX.
For some reason it crashes where the curve is at the 0,0,0??? I do not know why. Sketch a line across it and do an extrude with stop at intersections is turned on. I attached a PRT file. Thanks
That was a limitation which I personally found and reported as a PR, and which I was under the impression that this was fixed in either NX 10.0 or NX 11.0
Thank you for all the input!!! After the holiday I will be looking into this further to see if the involute part i downloaded can actually work with what we are designing!
If the Law Curve approach isn't working, there is an alternative. If you look in some location like C:\Program Files\Siemens\NX 10.0\UGOPEN\SNAP\Examples\More Examples\Gear on your system, you will find a SNAP program that creates simple spur gears. Part of this is the construction of an involute curve.
