mod3302
- Jan 2, 2013
- 7
Scenario
In one of the ships, ballast system for the vessel has routed with an inverted U in pump suction line. This is not an avoidable situation due to space constraints and room arrangements in the vessel.
Refer drawing TANK802P-SUCTION LINE.pdf, here this is typical line from one tank, the function is to transfer sea water from this tank (802P) to overboard (to sea, outside the ship). this is basically to adjust the vessel stability based on various conditions. The vessel has several such tanks. But pump suction is considered only one at a time. In this present situation we are having difficulties in getting suction from some tanks (geometry is similar to attached one for most of the tanks). We have checked for air leaks but seems no such leaks existing.
We have also tried to operate the pump by fill the vent pipe with water, but that was also not successful, pump run for some time. Water height was around 14m (sensor is place 50mm above the tank bottom) including the air vent height. The pump was started after closing the overboard discharge valve. (Suction pressure 1.03 bar, pump discharge pressure 6.58 bar). The overboard valve was half opened then, causing continues flow for some time. Then the discharge pressure reduced to approx. zero bar and suction pressure of (-) 0.22 bar. Tank water height was around 6m at this time.
Pump capacity is 200m3/hr at 5 bar.
Kindly review and advice.
