D
Dominic Greco
Guest
I just switched over to Inventor 2008 from Solid Edge and was wondering if there was an add on program, or if Inventor had a feature akin to Solid Edge's "Revision Manager".
If you are unfamiliar with this software I can explain. It is a stand alone program that comes with Solid Edge. It allows you to pick an assembly, part, weldment, or drawing and it's tree structure will show up in a browser window. From this window you can adjust file properties (iProperties), rename or move files, while maintaining the link to the main assembly. This is particularly useful for copying/moving large multi part assemblies to a network drive. It's also very useful to help resolve broken links in an assembly.
Is there an Inventor equivalent to this program?
Dominic
Dominic
