Has anyone had any luck using Inventor for exhaust pipe fixtures or multistage (forming) presstools yet?.
How about modelling things in an assembly that are non contacting (yet positioned in relation to each other on a fixture) and at compound angles in 'car line' orientation?.
If you can follow what on earth Im describing, lol.
For example, an exhaust pipe which has flange/mounting plates on each end & multiple brackets along its 3d path positioned in space at different radial positions along pipe and around pipe bend sectons etc..
The partially surfaced iges pipe data sent is usually positioned in 'car line', ie way out in space at like x3500mm,y2567mm,z1235mm etc and may need orientating a particular way round relative to the fixture 'baseplate'. eg, to get a particular portion of the pipe perfectly axial in normal space, or a bracket horizontal etc.
Just curious to whether its possible to do fully inside in Inventor yet......Some linked examples or know how in this area would be fantastic as Im still lost in how inventor etc can do these tasks, we cant all be product designers
Im gonna pester the SolidQuirks and SolidEgg crew aswell, lol.
Thanks for any response,
Sirius.
Sirius.
