Hi - I've just started working with inventor 2008 after 10+ years of Solid Edge and SolidWorks and I've encountered a problem that I desperately need solved - how can I get the drawing views (draft or inventor dwg file) to update when I make a change to the model? I've tried the update and rebuild all commands and the views just will not update. If i delete the view and insert again it is correctly updated. This seems to be happen when the change is minor (change model dim by 0.100")
