USAeng
- Jun 6, 2010
- 419
In a power plant there is a fan that blows air into a header. After the header there are 3 6" air ducts. I need to get an intrument installed in each header so that if any or all of the ducts begin to become blocked off past a set amount then the switch will activate and shut off a fuel system. I am confused on if I should use a pressure switch or a pitot tube. It seems to me the pitot tube would be the correct one because it would measure velocity pressure which would be the difference in the ducts... the pressure switch would be measuring static pressure that would be equalized in the ducts and header if a duct were beginning to clog. Thanks for any input!
