I have been an air balancing technician for years and have thought of centrifugal fans similar to centrifugal pumps in that they both create a pressure difference. This pressure difference is what starts the fluid moving.
I am working more and more on various sizes of closed loop hot/chilled water hydronic systems. When it comes time to determine pump flows from the supplied performance curve, I usually find that the pump flows are "off the chart"; above the pump curve, so to speak. I have always thought of this as an inefficient place for a pump to be; that is to say energy is being wasted.I have just calculated very high pump flows but using about 60% of the rated amps on the motor. My assumption is that the pump is likley to be over-delivering. Is this a correct assumption and what is the pump doing if it is not on the manufacturer's plotted curve? Is there a reference for reading on this subject?
