Interpolating
rm2
MX
I have to vectors (flow and pressure).
I am scatter plotting them (flow vs pressure). I did it before, I do not recall how I interpolated around for a certain value of let say pressure and have the flow value on that specific point...
hope anyone can help me, thanks
Have you tried linear interpolation?
Excel has functions for curve fitting, like linest and logest, from which you get the parameters for doing the interpolations.
TTFN
FAQ731-376
is it interp2?
I will try tomorrow morning
Do you want an interpolation or a best fit line?
use "polyfit" for the latter
M
Dr Michael F Platten
Interpolation
I'm sure there are some built in excel functions that's do what you want.
Personally rather then worrying about that syntax I would rather just write the formula. Then you can do the same thing in Matlab or Maple or whatever. Math works in any language.
Step 1: What is the slope of a line passing through two points: (X1,Y1) and (X2,Y2).
Think about it before you read the answer.
Answer: slope = (Y2-Y1)/(X2-X1)
Step 2: How do I use that slop to find the value of Y at some arbitrary X in the interval (X1,YX)?
Answer:
Y = Y1 + slope * (X-X1)
Sorry I am not trying to be a jerk. It is something you should spend time understanding (rather than memorizing) imo.
obvious typo correction in bold:
Step 2: How do I use that slope to find the value of Y at some arbitrary X in the interval (X1,X2)?
I apologize if I have underestimated your problem. Maybe you want a general formula to work with two columns of X, Y data. Then you need to use some lookups if you are going to build the arguments for the interpolation formula if you are going to build it yourself.
Here is a vba function to return the interpolation from a range of X's and Y's:
Code:
Function InterpL(LookupValue, KnownXs, KnownYs)
Dim pointer As Integer
Dim XO As Double, YO As Double, X1 As Double, Y1 As Double
pointer = Application.Match(LookupValue, KnownXs, 1)
XO = KnownXs(pointer)
YO = KnownYs(pointer)
X1 = KnownXs(pointer + 1)
Y1 = KnownYs(pointer + 1)
InterpL = YO + (LookupValue - XO) * (Y1 - YO) / (X1 - XO)
End Function
And yes this is linear interpolation. For a higher order interpolation you need a spline technique. Let us know if you are interested in that.
Hmmm. I thought I was in the excel forum - hence the vba function. IRStuff sent me off track (or maybe I just wasn't paying attention).
Use interp1 for simple interpolation like you are talking about.
Interp2 is for 2-d interpolation.
There is a lot of help in the help
If you are using interp1, be sure that your independent axis (you haven't told us whether it's pressure or flow) is monotonic.
- Steve
