Interpolating Results from a mesh to another mesh in Ansys
Ahmadoo
CA
Hi
I would like to use the structural results (nodal stress, velocity and acceleration) of a "WB Transient Structural" (WBTS-1) model as initial conditions for another "WB Transient Structural model" (WBTS-2).
The WBTS-1 is simple plate bending case and I used the "WBTS Beta Version" to create the deformed geometry at the end of simulation.
Then I exported the deformed geometry of WBTS-1 to FE Modeler and from there to the WBTS-2. Also, I used "INISTATE, WRITE, 1, , , , 0, S" in the WBTS-1 and created an IST file containing the nodal stresses of the WBTS-1 simulation.
In the WBTS-2 I used "INISTATE, READ, file, ist," to read the WBST-1 results as the initial conditions.
The problem arises here: Since the IST file is sorted based on node numbers only and since the node numbers are different in the WBST-2 (because of different mesh) the mapping does not occur correctly.
I was wondering if you have any macro which interpolates the data between two meshes?
Thank you very much
What version of Workbench are you using? In v13, you should be able to drag-and-drop a transient structural model to read the results from your static structural model. However, if you have two different meshes you could run into a problem.
The CBDOF command can be used to interpolate results onto a sub-model. BFINT can likewise be used to map body forces. Interpolation commands (esp. BFINT) can take a bit of oompf to do their thing, so be prepared.
From the sound of it, you should probably be working in Ansys APDL, but with a few command objects you can probably trick Workbench into doing what you want it to do.
//signed//
Christopher K. Hubley
Mechanical Engineer
Sunpower Incorporated
Athens, Ohio
