A 14 teeth pinion with standard addendum will have “undercut” so there’s a good chance it has a plus addendum modification. If this is the case and the gear has no equivalent minus correction, then the standard calculation for hard mesh center distance, sum of the two P.C.D.s divided by two, can not be used because the operating pressure angle is no longer the same as the standard pressure angle. You need to have more information before the center distance can be worked out.
