internal spur gear
  • Thread starter Thread starter knave
  • Start date Start date
K
knave
Guest
hi guys
anybody got a model of an internal spur gear that they would be willing to share?
there is a model of an internal spline on the files page but i need a spur gear profile
cheers
dave
Dave;
1. Take the Spur Gear and down load it.
2. Create a new blank gear.prt.
3. Create an assembly.
4. Assemble the blank gear.prt. (YOUR GEAR).
5. Then assemble the Spur Gear .
6. Now you can do a modify/modify part/feature/
feature create/cut.
7. Now use the Spur Gear to create a profile.
8. After you are finished with the cut. save the
assembly. (erase not displayed)
9. Open (your_gear.prt), Redefine cut Pro/E will ask
you about the referances to the Spur Gear. Make sure
you remove all referances.
10. Re-dimension cut and save.
11. Congradulaions you now have an Internal Spur Gear.
