For a lube oil pump (gear type) of a compressor only an internal pressure relief valve is in place. I am sure that there should also be an external relief valve as there are some valves in pump discharge. Can somebody tell me where I can find this requirement. The pump will serve on a plant located in the UK so european guidelines are mandatory.
thx
thx
