Intermediate Forces in OpenSTAAD
boyq
3
Hi. I'm new to OpenSTAAD. I wanted to output a table for Section Forces at given distance which is not covered by STAAD default increments(up to 12).
I know I could use "Print Member Sections Force List" Command and defining a custom section but the output is not usable in excel since it's not tabulated so I thought of utilizing STAAD's built-in macro.
Here's my code that doesn't work:
Sub Main()
'Description:Intermediate Forces
Dim objOpenSTAAD AS Object
Dim beam As Long
Dim dist As Double
Dim LC As Long
Dim Force(0 TO 5) As Double
Set objOpenSTAAD = GetObject(,"Staad.ProOpenSTAAD")
beam = 120
LC = 701
For dist = 0 TO 3 Step 0.467
'Get Intermediate Forces for Member 120 (Length=3m) at 1.4m for LC 701
objOpenSTAAD.Output.GetIntermediateMemberForcesAtDistance (beam, dist, LC, Force(0))
Next dist
Set objOpenSTAAD = Nothing
End Sub
Your suggestions are appreciated.
I just utilized convert text-to-column wizard of MsExcel instead and it was now able to tabulate staad output data to my worksheet.
Consider this as solved.
Structural Engineer
Dear boyq
This is OpenSTAAD code in Excel for taking output results
Option Explicit
Sub Main()
Dim objOpenSTAAD As Object
Dim BeamNo As Long
Dim Dist As Double
Dim LC As Long
Dim Force(0 To 5) As Double
Dim x As Integer
Set objOpenSTAAD = GetObject(, "StaadPro_OpenSTAAD")
BeamNo = 230
LC = 3
x = 0
For Dist = 0 To 3 Step 0.467
objOpenSTAAD.Output.GetIntermediateMemberForcesAtDistance BeamNo, Dist, LC, Force()
Worksheets(ActiveSheet.Name).Cells(3 + x, 1).Value = Dist
Worksheets(ActiveSheet.Name).Cells(3 + x, 2).Value = Force(0) '******FX
Worksheets(ActiveSheet.Name).Cells(3 + x, 3).Value = Force(1) '******FY
Worksheets(ActiveSheet.Name).Cells(3 + x, 4).Value = Force(2) '******FZ
Worksheets(ActiveSheet.Name).Cells(3 + x, 5).Value = Force(3) '******MX
Worksheets(ActiveSheet.Name).Cells(3 + x, 6).Value = Force(4) '******MY
Worksheets(ActiveSheet.Name).Cells(3 + x, 7).Value = Force(5) '******MZ
x = x + 1
Next Dist
Worksheets(ActiveSheet.Name).Cells(3, 1).Value = "Dist"
Worksheets(ActiveSheet.Name).Cells(3, 2).Value = "FX"
Worksheets(ActiveSheet.Name).Cells(3, 3).Value = "FY"
Worksheets(ActiveSheet.Name).Cells(3, 4).Value = "FZ"
Worksheets(ActiveSheet.Name).Cells(3, 5).Value = "MX"
Worksheets(ActiveSheet.Name).Cells(3, 6).Value = "MY"
Worksheets(ActiveSheet.Name).Cells(3, 7).Value = "MZ"
Worksheets(ActiveSheet.Name).Range(Cells(3, 1), Cells(3, 7)).Font.Bold = True
Worksheets(ActiveSheet.Name).Range(Cells(3, 1), Cells(2 + x, 7)).HorizontalAlignment = xlCenter
Worksheets(ActiveSheet.Name).Range(Cells(3, 1), Cells(2 + x, 7)).VerticalAlignment = xlCenter
Worksheets(ActiveSheet.Name).Range(Cells(3, 1), Cells(2 + x, 7)).NumberFormat = "0.000"
End Sub
