interlaminar shear stress 1
engroma
CH
Hi
I have to evaluate by means of hand calculations the interlaminar shear strength and strain.
I have been thinking of using the ply x and y components of stress, but I am not confident that is the right procedure.
Do you have any advise or literature or paper ?
thanks
Ingroma
Look for the book:
Analysis and Performance of Fiber Composites
I agree that it is not the right procedure. You do, however, need to know the orientation of the fibers in the x and y directions and convert them, by means of a lot of matrix algebra and calculations, into the longitudinal and transverse load scenarios. Then, by more matrix algebra and such, you will be able to find shear strains/stresses.
If you have to do this by hand, I would suggest Mathematica to make your own formulas and simply input your given values.
You need to know literature values such as, Moduli, poissons ratio, shear modulus, Ect., but you may have work around what you know with the formulas. Also, try looking up Halpin-Tsai equations. They have found revolutionary formulas regarding composite performance prediction.
