It just depends on the AHJ. Much of what I do is delegated design for interior framing, exterior framing, and non-structural component support. For our interiors, about half of that work is driven because the design team has it listed as a deferred submittal; however, a lot of the larger drywallers we work with will seek out engineering to limit their liability.
That being said, I have to disagree with Dave here. In my experience, the drywallers definitely know how to construct things that are stable but they don't hit the mark when it comes to building something 'up to code.' More often than not, nearly everything is undersized because they pull the sizes from limiting heights schedules and don't read or understand the little caveats within those tables (like notes that require "bracing to develop full moment capacity.") I could go on listing examples forever; but my point is that they know how to build but they don't know how to design/size/detail.
Now for the more controversial part, I also find that there are MANY EOR's who apparently don't understand light-gauge framing themselves. Just as often as I see undersized members in the field, I see undersized members within design drawings by EORs. Heck, I've seen an EOR specify a PAF in concrete to resist tension in a Seismic Category D region; the worst part is the PAF they specified was a Gypsum-board to metal stud fastener and had no loads listed for installation to concrete. It is obvious that to many of the EOR's out there, the light gauge framing and non-structural components are merely an afterthought for them; something you dig into your archives to look for a few typical sizes and details and hope that the plans reviewers don't ask for calculations.
mwhite, if you are not going to do the design yourself, I would implore you to put a lot of thought into creating realistic parameters to guide the delegated designer. The worst projects are when the EOR doesn't communicate what their structure was designed for. The better projects are when the EOR provides some kind of input on how they designed their building and communicate the limitations of their structure (roof deck designed for maximum point loads of xxx @ xxx o/c). The best projects are when the EOR maintains some kind of realistic expectations with those limitations; if one more EOR tells me their structure wasn't designed to support the interior suspended ceiling that has been shown in the Arch. drawings since day 1, I might lose it (please, please, PLEASE, remember that buildings are meant to support more than just their self-weight and live loads).
Judgement-In-Training
