Interior CMU Partition Wall 1
PittEng88
90
Hi All,
I am currently designing CMU partition walls (non-load bearing) that are 16' high, for an existing building in Puerto Rico. The architect has proposed a steel support frame for behind the walls to provide bracing at mid-height and the top of the walls, see attached image. The length of the long wall is 30' and the short wall length is 6'. The only loads that I anticipate for these walls are their own selfweight, a live load of 5 psf and their seismic loads (SDC = D). Due to the walls being installed in an existing building, I would like to reduce the amount of loads induced on the existing structure as much as I can. Therefore, I would like to avoid attaching the walls to the roof and to consider the connection at the bottom of the wall as pinned. I am planning on using either 8" or 10" block.
My question is, would I be able to eliminate the steel frame and be able to use just bond beams at the top of the wall and mid-height to provide enough stability for the wall? I.E. for in-plane loads, design the wall as a two story shear wall with the bond beams acting as the chords to distribute the shear force into the wall, and for out-of-plane loads, consider the bond beams as simple supports for the walls.
I hope I explained myself clear enough. However, if you have any questions or need more clarification feel free to ask. Any and all suggestions will be welcomed. I am a little green when it comes to designing w/ masonry.
Thank you for your time,
Mike
 http://files.engineering.com/getfile.aspx?folder=c79051f6-bea5-4d7a-8d1a-6f6770047b03&file=CMU_Wall.jpg
Rolled channels with toes down will require chipping of block. Rolled channels with toes up will work but require angles.
Sorry for any confusion.
Jike, why the angles? I would bolt through the web into the wall.
Oh, I was envisioning a different detail.....I get what you are describing.....that works.
And I thought Hokkie was forgetting about the canted/slopped nuts after all his years spoiled with Parallel Flange Channels in Aussie!
I do forget lots, but haven't forgotten those bevelled washers.
Bevelled! Damn; I just specified them on a job and the term escaped me...
