Czinczar
- Mar 24, 2005
- 3
I am using a PIC18F452 to run program controlling a stepper motor and i need to interface a driver circuit to supply the power needed to move the motor. The program works fine and the logic output from the PIC is good. My problems come at the power stage. I have tried the ULN2804A witch is a hex driver that can operate at 50v max and 500 mA max but i cant get any output from it. Then i tried to use the discret components approch. My goal was to inverts the logic signals from the PIC using a DM74LS04N and use it to controls tansistors but the inverter behavied weerdly (some of the pin had 0.88v, other were at 2.8v, other at 4.1). Could a PIC be unable to drive some type of inverter? I am developping on a breadboard, could the signal from the crystal cause noise on the circuit?
