Investigations into a recent 400 hp motor failure uncovered that the pump dedicated to the motor was serviced and was to be put back in service. Incorrect procedures were followed in terms of opening suction and discharge valves. As a result of the system architecture the impeller began to rotate in the opposite direction subsequent to which the motor was started.
Curiously on examination the stator windings looked fairly ok based on what happened. No excess dirt or moisture, insulation OK, no major burns/soot etc. I expected more severe damage though.
(Magnetic overload was defective)
What I am curious about though is the mathematical analysis of this situation. Considerations, equations, conditions and theories.....
Where to start? I know I would have to consider the locked rotor current etc....
