1
- #1
auzie5
- May 8, 2009
- 94
Pipelines are typically constructed using a combination of “roping” (grading the right of way to reduce the number of required factory and field bends) and “bending” (using field bends to accommodate undulations discovered along the right of way during construction).
Roping analysis can be performed at the design stage to define bend radius limits for roped pipe (e.g. ~1500m minimum bend radius limit for NPS 20 pipeline).
The benefits of roping include defining during the pre-installation phase the optimal pipeline profile to reduce global buckling risk, minimizing trenching cost, and enhancing construction efficiency.
Inertial measuring unit (IMU) in-line inspection (ILI) tool runs are commonly used to as-built newly constructed buried midstream pipelines. Bending strain reports generated from the IMU data can be used to identify locations along the pipeline where cold/shop bends are present. Bending strain reports generated form the IMU data can also be used to identify location along the pipeline where sections have been “roped” to match the contours of the route curves (either horizontal or vertical).
IMU data can be used to generate an as-built pipeline profile in an FEA program. Using the IMU data to identify cold/shop bends versus roped sections allows one to identify areas where no elastic bending stress remains (i.e. cold/shop bends) versus areas where some nominal elastic bending stress exists (i.e. roped sections).
Question: When performing stress analysis on the as-built pipeline system, if roped sections can be identified, should the elastic bending stress be calculated and superimposed on top of operating stresses in the FEA analysis?
HDDs are a good example where pipe is roped to match the route curve (i.e. HDD profile). Since roped pipe remains in an elastic bending state, it is common for HDDs to account for the bending stress that permanently remains and the bending stress is added to the operating stresses (gravity, pressure, thermal). However, I do not typically find that people spend the time to review the IMU data to identify every mainline location where roped pipe is present and then include the elastic bending stress calculated at those locations in the stress analysis. Typically roped sections on mainline have extremely high bend radii (~500m to 1500m) but even with a high bend radius, the elastic bending stress can make a significant difference in the stress analysis results.
I find it interesting that Australian pipeline standard AS-NZ 2885.1:2018 directs users to omit roping stresses. The "note" is particularly interesting. I was recently qualifying a fusion bond epoxy external coating and when we removed longitudinal coupons from the coated line pipe, the coupons (1" wide x 24" long) sprang up like a canoe (evidence of residual stress remaining from manufacturing). The point being that there may be other residual stresses in addition to roping stresses that are not accounted for during stress analysis (e.g. pipe manufacture and girth welding).
The following excerpt taken from Australian / New Zealand pipeline standard AS-NZ 2885.1:2018:
5.7.5 Stresses due to construction
This Standard does not limit stresses prior to hydrostatic testing. Strains, deflections and displacements shall be controlled so that—
(a)strain does not exceed 0.5% except where strain is displacement controlled, (e.g. cold field bending within an approved procedure, forming of pipe ends for mechanical jointing, weld contraction etc.); and
(b)diametral deflection does not exceed 5% of diameter.
Residual stresses left in the pipe after construction (e.g. roped bends) do not need to be considered in the calculation of operating stresses, provided the pipe has good lateral restraint (e.g. laid in soils of normal strength). Where lateral restraint is weak or absent, consideration shall be given to preventing the possibility of uncontrolled strain due to the combination of residual stresses with either hydrostatic pressure test stresses or operating stresses.
NOTE: Pipe manufacture, girth welding and pipe-laying all result in residual stresses (potentially as high as yield stress), which conventionally are neglected in pipe stress analysis because they are not associated with any failure mode; however, it is conceivable that failure by deformation or buckling during hydrostatic testing may occur in a pipe containing high longitudinal residual stress but lacking lateral restraint (or during operation if lateral restraint is removed subsequent to a successful hydrostatic test).
