apsix
- Sep 21, 2004
- 1,358
I need to determine the capacity of existing bracing so that I can match it.
The existing bracing members are 2 - 152x152x10 Angles, starred. These are arranged in the normal cross, in addition to horizontally at mid-height (refer attached).
Bay size is approximately 6.5 x 6.5m.
I suspect that the intent was for the bracing members to act simultaneously in tension and compression.
Does anyone agree?
Does the horizontal member appear sufficient to act as a lateral restraint to the braces in compression? (I will calculate it, I'm just looking for informed opinions at this stage).
Does anyone agree?
