I have a requirement to insulate the ceiling of a server room as the floor above is getting cold because of the server room cooling.
Planning to use xlpe (PE cross linked material) as the insulation.
How to know how much insulation thickness required ?
I got this formula for heat transfer Q = K * A * (delta T) / X
Q - heat load (watts)
K - thermal conductivity
A - area across which heat flows
delta T - temperature difference
X - insulation thickness
I want to calculate X. but got stuck on calculating Q. Cld please give some inputs on this calculation of heat load.
Server room is maintained at 20 degree Celsius. And I measured above floor temperature and that is at 22.7 degree Celsius which has to be at 29 degree as per the user.
