Insulation tester - what brand/type is ideal for electric motors 1
simpleoelectrician
1
I have been looking on the net for a insulation
tester. I intend to use it mainly for testing motors.
I would like know what you would consider to be the
ideal tester for the task.
I have also been trying to locate information on
testing procedures. It has been very difficult to
find such information. I tried a search at this site
with zero results.
Do you know of any sites with motor insulation testing information? Do have any tips for testing?
I would greatly appreciate any information.
Respectfully,Ruben
There are many types of motor testers
Megger - Testing the insulation resistance and polarization index of windings (Avo, Fluke, Kyoritsu)
Surge Tester - Testing the turn-to-turn insulation, reversed coils, etc. (Baker, PJ Electronics)
AC HV test kit - Testing the high voltage withstandability of windings (many make them, google for ac hv tester)
DC HV test kit - Non-destructive (within reason) testing of the winding dielectric strength of winding (Google for dc hv tester)
Micro-ohm meter - Testing the winding DC resistance (Avo, Fluke)
* I would go green if only I were not yellow *
My primary tools were a hand cranked megger with a 1000V scale, a 500V scale, and a 6V low ohms scale, also a clamp-on ammeter and a good quality multimeter. The 6V low ohms scale on the megger will do some of the work of a micro-ohm meter on motors up to about 5 or 10 HP. These located about 99% of my motor problems. Once or twice I have had to send a motor into a good winding shop. I had a motor overheating for no apparent reason. The motor shop determined that there was an internal fault in the casting of the aluminum squirrel cage in the rotor and arranged for a warranty replacement.
But times change and if I got back into service work in North America I would probably add equipment to measure total harmonic distortion, and possibly some type of multi channel recorder, maybe laptop based. Temperature measurement would also be good.
Bill
"Why not the best?"
Jimmy Carter
What voltage motors are you testing? You want to get a Megger that has the appropriate test voltages and for motor teting one that calculates your DAR and PI for you. If you have a lot of motors then get one with data storage.
I have never owned anything but my Biddle Megger (now AVO). No failures or problems in 25 years.
