I am trying to make a protective casing for documents using high temperature ceramic or calcium silica fiber blankets. The document will be wrapped in the casing and placed into a furnace for 1350 F for 15 mins and will record internal temperature of the document. I am looking to mathematically find out how long it will take either fiber blankets to reach 350 F internally. The heat flow rate is given for each material and also the dimensions. The thickness of the blanket will be about 2 inches but can vary for .5 in to 2 in if needed.
Thank you
Thank you
